Using DE10-nano GPIO1/GPIO0 from Linux
I’m trying to use GPIO on DE10-nano evaluation board connectors JP1/JP7. From documentation I assumed these IOs directly accessible from HPS.
However, by using various demo C code I only managed to access user LED which also blinks under control of the FPGA. The rest of GPIO remain in high-Z (1.6V).
I also tried to operate GPIOs via /sys/class/gpio interface. After exporting all available numbers I have gpio427 to gpio511 directories under /sys/class/gpio. But still writing to gpioX/direction and gpioX/value files has no effect on the lines on JP1/JP7.
Do I have to configure anything else before accessing GPIO from HPS?
- EBERLAZARE_I_Intel
Have you run though the "Example for HPS SoC" in the DE10-nano user manual in Chapter 6?
Regards.
- jackhab
I finally got it running after I found out the GPIO on JP7 connector are mapped in Linux starting at number 107.
Great, please let me know if there is any more problem that you encounter or any questions you want to ask. Thanks.
