14 years ago
USB blaster installation problems in W7 64bit
:confused:
How can I install USB blaster in Windows 7 64 bit? it just can´t install the drivers correctly, every time I connect the tool to my PC it tries to install the already installed drivers but at the end it appears with an error and it doesn't work.
If I uninstall the drivers and try the whole process again it does the same and I can't make it work.
Do anybody know how can I install the drivers properly?
Thanks!!
    Some versions of the board test system are a bit fragile. Does the standard SystemConsole detect anything? (are there nodes under /devices in the system explorer window)
    Thanks Wombat for the answer.
    I was able finally of installing the Usb-Blaster.
    I reinstall the jtagserver.exe which is not running when you install the quartus II 12.0.
    So now, the Quartus and the Board Test System are detecting de USB-Blaster :).
    but other problem is showing up.......Board test system is not initialized?? is block on the starting message
    Thanks for the fix pinhedd and others. As mentioned installing TBB V9 fixes the problem.
    I have Windows 7 64 bit.
    I installed Quartus V12.0sp2 and kept getting the error.
    Error (209066): The instruction register length for the EP4CGX15BF14 device at position 1 in the JTAG chain is unknown
    Error (209012): Operation failed
    When trying to program.
    I installed the stand alone programmer for 12.0sp2 and hey presto the problem went away.
    Just like it did on the previous versions (11.x).....
    Seriously guys......
    Getting Quartus II to see the USB-Blaster was a real pain. It took hours of grovelling. I don't know which of several changes finally made the difference. Candidate are:
    * Fall back to an old version of Quartus II (10.1)
    * Use an old USB-Blaster driver from 2009.
    * Install the USB-Blaster driver before installing Quartus II.
    In a fairness to Altera and MickeySoft, it might have been a firewall or browser problem.
    --- Quote Start ---
    --- Quote End ---
    And now I cannot see USB blaster through the programmer any more.
    Seriously. Altera software is utter %^&#.........
    If I could walk away from using this joke development system right now I would.
    I'm not sure what's going on here, but I just installed web version 12.0 and had the same problem. The solution was to install version 10.1 of the stand along programmer. Go into devices manager and "update" the driver (right click on usb blaster) to the older version that is installed in the drivers folder of the 10.1 stand along programmer. maybe 11.0 would work as well. This is kind of lame (same type of system Win 64 sp 1 version 7) . I had to do this for my starter kit, not a terasic usb blaster as someone else mentioned. After doing all of that then I could get the hardware drop down in the programming software finally. Seems like a big bug, unless my system is just weird, although it sounds like at least a few people have this same problem.
    --- Quote Start ---
    Turns out my problems weren't completely solved either. The Quartus programmer worked, but the development kit software didn't. The development kit stated that its version was 10.1, so I downloaded the stand alone programmer 10.1 from and now it finally works!
    monnoliv, check the version of your MAX V board test system and download the associated stand alone programmer to get the right drivers. Otherwise, the attached drivers are of version 10.1 if you would like to try these instead...
    --- Quote End ---
    This definitely works. Something to do with this version of drivers included... Just use SP1 USB blaster driver.
