14 years agoUSB blaster installation problems in W7 64bit
:confused: How can I install USB blaster in Windows 7 64 bit? it just can´t install the drivers correctly, every time I connect the tool to my PC it tries to install the already installed drive...
14 years agoThanks Wombat for the answer.
I was able finally of installing the Usb-Blaster. I reinstall the jtagserver.exe which is not running when you install the quartus II 12.0. So now, the Quartus and the Board Test System are detecting de USB-Blaster :). but other problem is showing up.......Board test system is not initialized?? is block on the starting message
