APaci1
7 years agoTSE_MAC Triple Speed Ethernet - HOW TO SET MAC FILTER ?
Hello! I'm try a TSE IP Application (10/100/1000 MII/GMII with Fifo settings)
I want enable MAC FILTER on receive frames:
I set TSE_MAC control register as:
TSE_CTRL_FRM_ENA = 1 (control of rx frames enabled)
TSE_PROMIS_EN = 0 (promiscous mode off)
I set primary Macs with LSB=0 or LSB =1 to try (Unicast/multicast)
I try to set all 4 secondary macs as the primary (BUT WHEN I READBACK VALUE TSE GIVE ME 0, instead primary mac is correctly read/write)
Well (or Damn'd) , mac filter doesnt' work and TSE on rx user side give me all frames that arrives from the LAN..
The hard point is why I cannot write secondary Macs?
Have you meet similar issue?
(Quartus 18.1, arria10 device, IP TSE)
1 Reply
- SengKok_L_Intel
Hi Sir, Tested the TSE MAC filter in simulation. It work well. Did you follow the link below, section 5.3.1 for the recommended initialization sequences? https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf Regards -SK
