Trouble building GHRD for DK-DEV-AGF014EA
- 2 years ago
Apologies for delay, as there was internal technical issue/glitches at our Forum Due to this case was not assigned.
There is rocketboard page for this development kit. You can use the GHRD and GSRD from below link-https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRD
You can also follow the below steps-
1. git clone -b QPDS24.2_REL_GSRD_PR https://github.com/altera-opensource/ghrd-socfpga
2. Enable Quartus tools to be called from command line:
export QUARTUS_ROOTDIR=~/intelFPGA_pro/24.2/quartus/
export PATH=$QUARTUS_ROOTDIR/bin:$QUARTUS_ROOTDIR/linux64:$QUARTUS_ROOTDIR/../qsys/bin:$PATH
2. make config
This command have the options for available parameterization of GHRD and knowing the default parameterization
3. Customize the GHRD settings via 'make' command along with 'generate_from_tcl' command as well.
Multiple <PARAMETER> may be customized at one time [Not necessary if the default option is good], example- make <PARAMETER>=<value> generate_from_tcl
example- I have used this below command and tested for Agilex-5
make DEVICE=A5ED065BB32AE6SR0 HPS_EMIF_MEM_CLK_FREQ_MHZ=800 HPS_EMIF_REF_CLK_FREQ_MHZ=100 generate_from_tcl
4. make all
This command to Compile Quartus Project and generate the configuration file.
Tiwari
Tiwari
