fwadswor's avatar
fwadswor
2 years ago
Trouble building GHRD for DK-DEV-AGF014EA
Similar to a previous post, I am unable to build the GHRD for the Agilex™ 7 FPGA F-Series Development Kit (P-Tile and E-Tile) device. Following the instructions on RocketBoards for the seemingly most...
  • Jeet14's avatar
    2 years ago
    Apologies for delay, as there was internal technical issue/glitches at our Forum Due to this case was not assigned.
    There is rocketboard page for this development kit. You can use the GHRD and GSRD from below link-https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRD
    You can also follow the below steps-
    1. git clone -b QPDS24.2_REL_GSRD_PR https://github.com/altera-opensource/ghrd-socfpga
    2. Enable Quartus tools to be called from command line:
    export QUARTUS_ROOTDIR=~/intelFPGA_pro/24.2/quartus/
    export PATH=$QUARTUS_ROOTDIR/bin:$QUARTUS_ROOTDIR/linux64:$QUARTUS_ROOTDIR/../qsys/bin:$PATH
    2. make config
    This command have the options for available parameterization of GHRD and knowing the default parameterization
    3. Customize the GHRD settings via 'make' command along with 'generate_from_tcl' command as well.
    Multiple <PARAMETER> may be customized at one time [Not necessary if the default option is good], example- make <PARAMETER>=<value> generate_from_tcl
    example- I have used this below command and tested for Agilex-5
    make DEVICE=A5ED065BB32AE6SR0 HPS_EMIF_MEM_CLK_FREQ_MHZ=800 HPS_EMIF_REF_CLK_FREQ_MHZ=100 generate_from_tcl
    4. make all
    This command to Compile Quartus Project and generate the configuration file.
    Tiwari
