The programming time of the 10M50DAF256 in ISP clamp mode
we are using the 10M50DAF256 in the ISP clamp mode.
For Programming this device in the Clamp mode it is taking too long time Approximately 15Min. is there any solution to program it in the lesser time.
Krishna.
- KBVR
Hi WolfGang,
We rebuilt the PCB to resolve the Programming issue, now the unit will be programmed in normal mode. we are not using the ISP mode now.
Thanks & Regards
Krishna Prasad BVR
- ShafiqY_Intel
Hi KBVR,
If I not mistaken the issue is caused by Quartus Prime update version.
We will update the new KDB for this issue in near future. And this bug is scheduled to be fixed in a future release of the Intel Quartus Prime software.
In the meantime, please refer to the attachment picture for workaround:
I hope this will help.
Thanks.😉
- KBVR
Thanks for Quick response.
As per max10 Configuration guide In system programming time for 10M50 is 52.9 Sec.
but in my board it is taking too long time i.e 14min. please see the below info it is started at 13:21 ended at 13:35. is it hardware issue or tool issue?
and observed it is taking more time at performing verification process ( 209021)
Info (209060): Started Programmer operation at Mon Sep 30 13:21:15 2019
Info (209017): Device 1 contains JTAG ID code 0x031050DD
Info (209044): Erasing MAX 10 configuration device(s)
Info (209023): Programming device(s)
Info (209021): Performing verification on device(s)
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Mon Sep 30 13:35:44 2019
Thanks & Regards
Krishna
- ShafiqY_Intel
Hi Krishna,
May I know which Quartus version you are using?
Can your try it with Standard version?
