The programming time of the 10M50DAF256 in ISP clamp mode
Thanks for Quick response.
As per max10 Configuration guide In system programming time for 10M50 is 52.9 Sec.
but in my board it is taking too long time i.e 14min. please see the below info it is started at 13:21 ended at 13:35. is it hardware issue or tool issue?
and observed it is taking more time at performing verification process ( 209021)
Info (209060): Started Programmer operation at Mon Sep 30 13:21:15 2019
Info (209017): Device 1 contains JTAG ID code 0x031050DD
Info (209044): Erasing MAX 10 configuration device(s)
Info (209023): Programming device(s)
Info (209021): Performing verification on device(s)
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Mon Sep 30 13:35:44 2019
Thanks & Regards
Krishna
Hi Krishna,
May I know which Quartus version you are using?
Can your try it with Standard version?
