17 years agothe problem about sector and chip earse time of flash S29AL032D?
in the altera fpga starter developmet kit, the flash is S29AL032D,the time request like following:
Sector Erase Time 0.7 s Chip Erase Time 45 s but in the example, the Sector Erase Time is set to about 25.6ms, Chip Erase Time is set to 102.4ms, the result is nice, the kit works well. I am confused about this, anybody help me? thank you. the code of example: //Legal Notice: (C)2006 Altera Corporation. All rights reserved. Your //use of Altera Corporation's design tools, logic functions and other //software and tools, and its AMPP partner logic functions, and any //output files any of the foregoing (including device programming or //simulation files), and any associated documentation or information are //expressly subject to the terms and conditions of the Altera Program //License Subscription Agreement or other applicable license agreement, //including, without limitation, that your use is for the sole purpose //of programming logic devices manufactured by Altera and sold by Altera //or its authorized distributors. Please refer to the applicable //agreement for further details. module Flash_Controller( // Control Interface oDATA,iDATA,iADDR,iCMD, oReady,iStart,iCLK,iRST_n, // Flash Interface FL_DQ,FL_ADDR,FL_WE_n,FL_CE_n,FL_OE_n,FL_RST_n); ///////////// Control Interface //////////////////////// input [21:0] iADDR; input [7:0] iDATA; input [2:0] iCMD; input iStart,iCLK,iRST_n; output reg [7:0] oDATA; output oReady; ///////////// Flash Interface //////////////////////// output reg [21:0] FL_ADDR; inout [7:0] FL_DQ; output FL_OE_n,FL_CE_n,FL_WE_n,FL_RST_n; ///////////// Internal Register //////////////////////// reg [21:0] Cont_Finish,CMD_Period; reg [7:0] mDATA; reg [10:0] Cont_DIV,WE_CLK_Delay,Start_Delay; reg [3:0] ST; reg mCLK,mStart,preStart,pre_mCLK,mACT; reg mFinish; reg [2:0] r_CMD; reg [21:0] r_ADDR; reg [7:0] r_DATA; ///////////// Internal Wire //////////////////////////// wire WE_CLK; ///////////////////////////////////////////////////////// `include "Flash_Command.h" ///////////// Flash Command Period //////////////////// parameter PER_READ = 1; // 160 ns parameter PER_WRITE = 5; // 800 ns parameter PER_BLK_ERA = 160000; // 25.6 ms parameter PER_SEC_ERA = 160000; // 25.6 ms parameter PER_CHP_ERA = 640000; // 102.4 ms parameter PER_ENTRY_ID = 4; // 480 ns parameter PER_RESET = 1; // 160 ns ////////////// Flash State Machine //////////////////// parameter IDEL = 0; parameter P1 = 1; parameter P2 = 2; parameter P3 = 3; parameter P4 = 4; parameter P5 = 5; parameter P3_PRG = 6; parameter P3_DEV = 7; parameter P4_PRG = 8; parameter P6_BLK_ERA= 9; parameter P6_SEC_ERA= 10; parameter P6_CHP_ERA= 11; parameter READ = 12; parameter RESET = 13; //////////////// Clcok Setting ///////////////////// //parameter CLK_Divide = 4; parameter CLK_Divide = 8; //parameter CLK_Divide = 16; ///////////////////////////////////////////////////////// //// FL_OE_n ? Write = 1 : Read = 0 ///// //// FL_CE_n ? IDEL = 1 : ACTIVE = 0 ///// //// FL_RST_n ? ON = 1 : RESET = 0 ///// assign FL_DQ = FL_OE_n ? mDATA : 8'bzzzzzzzz ; assign FL_OE_n = (ST == READ) ? 1'b0 : 1'b1 ; assign FL_CE_n = (ST == IDEL) ? 1'b1 : 1'b0 ; assign FL_WE_n = (ST == IDEL) ? 1'b1 : (ST == READ) ? 1'b1 : WE_CLK; assign FL_RST_n = (ST == RESET) ? 1'b0 : 1'b1 ; assign oReady = mStart ? 1'b0 : mFinish; ///////////////////////////////////////////////////////// ////////// Flash State & WE Clock Generator ///////// always@(posedge iCLK or negedge iRST_n) begin if(!iRST_n) begin Cont_DIV <=0; mCLK <=0; end else begin Cont_DIV <=Cont_DIV+1; mCLK <=Cont_DIV[CLK_Divide>>2]; end end //////////////////////////////////////////////////////// ////////////// WE Clock Generator //////////////// always@(posedge iCLK or negedge iRST_n) begin if(!iRST_n) WE_CLK_Delay<=0; else WE_CLK_Delay<={WE_CLK_Delay[9:0],Cont_DIV[CLK_Divide>>2]}; end assign WE_CLK = (CLK_Divide == 4) ? ~WE_CLK_Delay[3] : (CLK_Divide == 8) ? ~WE_CLK_Delay[4] : ~WE_CLK_Delay[10] ; //////////////////////////////////////////////////////// /////////// Input Signal & Data Latch //////////////// always@(posedge iCLK or negedge iRST_n) begin if(!iRST_n) begin mStart <=0; Start_Delay <=0; preStart <=0; pre_mCLK <=0; mACT <=0; end else begin //////// State Active Detect ////////// if({pre_mCLK,mCLK}==2'b01) mACT<=1; else mACT<=0; pre_mCLK<=mCLK; ////////////////////////////////////////// ////// Input Signal & Data Latch ////// if({preStart,iStart}==2'b01) begin mStart <=1'b1; Start_Delay <=8'h00; r_CMD<=iCMD; r_ADDR<=iADDR; r_DATA<=iDATA; end else begin if(Start_Delay<CLK_Divide) Start_Delay<=Start_Delay+1; else mStart<=1'b0; end preStart<=iStart; ////////////////////////////////////////// end end //////////////////////////////////////////////////////// ///////////// Flash Output Latch //////////////////// always@(posedge iCLK or negedge iRST_n) begin if(!iRST_n) oDATA<=0; else if( mACT && (ST==READ)) oDATA<=FL_DQ; end5 Replies
////////////// Flash State Control //////////////// always@(posedge iCLK or negedge iRST_n) begin if(!iRST_n) ST<=IDEL; else begin if(mACT) // State Active Flag begin if(mStart) begin case(r_CMD) CMD_READ : ST<=READ; CMD_WRITE : ST<=P1; CMD_BLK_ERA : ST<=P1; CMD_SEC_ERA : ST<=P1; CMD_CHP_ERA : ST<=P1; CMD_ENTRY_ID: ST<=P1; CMD_RESET : ST<=RESET; endcase end else begin case(ST) IDEL: ST <= IDEL; P1: ST <= P2; P2: begin case(r_CMD) CMD_WRITE : ST <= P3_PRG; CMD_ENTRY_ID: ST <= P3_DEV; default : ST <= P3; endcase end P3: ST <= P4; P4: ST <= P5; P5: begin case(r_CMD) CMD_BLK_ERA : ST <= P6_BLK_ERA; CMD_SEC_ERA : ST <= P6_SEC_ERA; CMD_CHP_ERA : ST <= P6_CHP_ERA; endcase end P3_PRG: ST <= P4_PRG; P3_DEV: ST <= IDEL; P4_PRG: ST <= IDEL; P6_BLK_ERA: ST <= IDEL; P6_SEC_ERA: ST <= IDEL; P6_CHP_ERA: ST <= IDEL; READ: ST <= IDEL; RESET: ST <= IDEL; endcase end end end end //////////////////////////////////////////////////////// ////////////// Output Finish Control //////////////// always@(posedge iCLK or negedge iRST_n) begin if(!iRST_n) begin mFinish<=0; Cont_Finish<=0; end else begin if(mACT) // State Active Flag begin if(mStart) begin mFinish <=1'b0; Cont_Finish <=0; end else begin if(Cont_Finish < CMD_Period) Cont_Finish <= Cont_Finish+1; else mFinish <= 1'b1; end end end end //////////////////////////////////////////////////////// ////////////// Command Period LUT //////////////////// always@(posedge iCLK) begin case(r_CMD) CMD_READ : CMD_Period <= PER_READ-1; CMD_WRITE : CMD_Period <= PER_WRITE-1; CMD_BLK_ERA : CMD_Period <= PER_BLK_ERA-1; CMD_SEC_ERA : CMD_Period <= PER_SEC_ERA-1; CMD_CHP_ERA : CMD_Period <= PER_CHP_ERA-1; CMD_ENTRY_ID: CMD_Period <= PER_ENTRY_ID-1; CMD_RESET : CMD_Period <= PER_RESET-1; endcase end //////////////////////////////////////////////////////// //////////////// Command State LUT //////////////// always begin case(ST) IDEL: begin FL_ADDR <= 22'h000000; mDATA <= 8'h00; end P1: begin FL_ADDR <= 22'h000AAA; mDATA <= 8'hAA; end P2: begin FL_ADDR <= 22'h000555; mDATA <= 8'h55; end P3: begin FL_ADDR <= 22'h000AAA; mDATA <= 8'h80; end P4: begin FL_ADDR <= 22'h000AAA; mDATA <= 8'hAA; end P5: begin FL_ADDR <= 22'h000555; mDATA <= 8'h55; end P3_PRG: begin FL_ADDR <= 22'h000AAA; mDATA <= 8'hA0; end P3_DEV: begin FL_ADDR <= 22'h000AAA; mDATA <= 8'h90; end P4_PRG: begin FL_ADDR <= r_ADDR; mDATA <= r_DATA; end P6_BLK_ERA: begin FL_ADDR <= r_ADDR<<12; mDATA <= 8'h30; end P6_SEC_ERA: begin FL_ADDR <= r_ADDR<<16; mDATA <= 8'h50; end P6_CHP_ERA: begin FL_ADDR <= 22'h000AAA; mDATA <= 8'h10; end READ: begin FL_ADDR <= r_ADDR; mDATA <= 8'h00; end RESET: begin FL_ADDR <= 22'h000000; mDATA <= 8'h00; end endcase end //////////////////////////////////////////////////////// endmodule - Altera_Forum
Wow!
So, the chip on your board is Spansion not SST? And it also works when contain does big change again & again? Looks interesting~! - Altera_Forum
yes, the flash is Spansion.
i have tried to write a song into the flash using the example code, and the WM8731 can sing the song, so i say the board works well. Very strange! - Altera_Forum
It still works after re-programming?
Chip Erase time should around 1 minute for most of Flash 32Mb~64Mb in my experience. If this is true, you found a very fast way to make a Flash programmer. - Altera_Forum
--- Quote Start --- It still works after re-programming? Chip Erase time should around 1 minute for most of Flash 32Mb~64Mb in my experience. If this is true, you found a very fast way to make a Flash programmer. --- Quote End --- i tried a lot of times.sometimes,the kit works well after re-programming, when i long the chip erase time to 45s, everytime is nice. so i think the example code is wrong. as your mentioned, the code is for SST flash.
