Dover's avatar
Dover
6 years ago
The difference between the "JAM STAPL player" and "quartus_jli" ?
Hi all,
I want to find out a method to readback the USERCODE of the FPGA via the JTAG download cable (USB-Blaster) on my PC side.
  1. ​quartus_jli (Nios II Command Shell): I can readback the USERCODE.
  2. JAM STAPL player (Use Command Window): I cannot readback the USERCODE, it show the error message "I/O error: cannot open device \\. \ALTLPT1. Check port number and device driver installation."
I had found the following topic about the error message (https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd03311999_546.html), it seems that the ALTPLT1 is the driver 's name of the ByteBlaster cable.
If I want to readback the information by using the JAM STAPL player, do I must use the Byteblaster cable instead of the USB-blaster cable ?
Thanks a lot.
Dover
    • Dover's avatar
      Dover
      Hi John,
      Thanks for the reply.
      But could I have more simple method to readback the information without installing the whole Quartus software?
  • JohnT_Altera's avatar
    JohnT_Altera
    You just need to install Quartus Programmer Stand Alone software.
    • Dover's avatar
      Dover
      Thank you so much.
      I have reviewed the AN425 again. "quartus_jli" can be executed in the command window. It's not necessary to be execute in the Nios command shell.
    JohnT_Altera
    Yes, it can be executed in command window as long as you set the environment correctly.
