Dover
6 years agoThe difference between the "JAM STAPL player" and "quartus_jli" ?
Hi all, I want to find out a method to readback the USERCODE of the FPGA via the JTAG download cable (USB-Blaster) on my PC side. quartus_jli (Nios II Command Shell): I can readback the USERCO...
JohnT_Altera
6 years agoHi,
Unfortunately, the JAM STAPL does not support USB-Blaster. You may refer to https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd03152005_912.html. The reason is that the JAM STAPL is use for embedded system.
So I would recommend you to use quartus_jli if you would like to use USB-Blaster.
- Dover6 years ago
Hi John,
Thanks for the reply.
But could I have more simple method to readback the information without installing the whole Quartus software?
