navgh77
9 months agoStratix 10 FPGA Dev Kit VCCIO_FMC voltage issue
The FMC VCC IO voltage level is adjustable using a resistor on the board as shown below. The default is 1.8V and that works fine. When I depopulate the resistor (R468) to get 1.2V, the output voltage...
navgh77
8 months agoWhat do you mean by "follow the resistor settings"? The user guide mentions not installing the 3 resistors should get you 1.2V output. Is there another resistor setting guide I should be following?
