SD card Prebuilt binaries for Stratix-10 EVK
I am having the Stratix-10 Soc H-Tile with part number 1SX280HU2F50E1VGAS. How can I get the pre-built binaries for SD card booting?
Which procedure i can follow to flash images into an SD card?
Please help me regarding this issue.
Thanks in advance.
- mabdrahi
Contributor
Hi Tiru,
I will come back to you with the info soon.
please stay tune.
- Tirupataiah
Hi Mabdrahi,
Thanks for your response. I will be wait for your reply.
I hope it will be helpful to me.
- mabdrahi
Contributor
Thanks for your patience!
here is the link to the prebuild images.
https://releases.rocketboards.org/2023.04/gsrd/s10_gsrd/
Below is link to sdcard prebuild
https://releases.rocketboards.org/2023.04/gsrd/s10_gsrd/sdimage.tar.gz
below is how to flash to sdcard
- mabdrahi
Contributor
Hi Tiru,
Does the link useful for your case?
- Tirupataiah
Hi Mabdrahi,
Thank you so much for your response.
I have tried this procedure but EVK is not booting through Sd card.
One more important point is I am having H-Tile Stratix-10, not L-Tile Stratix-10.
I am not getting the proper procedure to boot from the sd card for H-Tile Stratix-10 Board.
Is there any different method of procedure for H-Tile Stratix-10 EVK SD card boot?
- mabdrahi
Contributor
I will it at my end, give me sometime to reproduce
- mabdrahi
Contributor
Hi Tiru,
The Stratix 10 SX SoC Development Kit H-Tile and Stratix 10 SX SoC Development Kit L-Tile are very similar boards, as documented at Intel Stratix 10 SX SoC Development Kit.
But, let work together to bring up the board using this page https://www.rocketboards.org/foswiki/Documentation/Stratix10SoCGSRDHTile
- mabdrahi
Contributor
Hi Tiru,
Do you have update from your side?
- mabdrahi
Contributor
Hi Tiru,
apologize to disturb you at this time.
May i iknow if you can boot if follow the link i give?
- Tirupataiah
Hi Mabdrahi,
Sorry for delay. I have tried that link you mentioned for H-Tile S10 EVK.
But, I am getting the error after entering the below command.
~/intelFPGA_pro/23.2/nios2eds/nios2_command_shell.sh make generate_from_tclI am attaching the error in the below Screenshot.
We are using nios2 command shell with version of 18.1 instead of 23.2.
- mabdrahi
Contributor
Actually we need to use quartus 23.2 to compile. I will give my generated sdimage to you.
give me some time to build it
