jwdonal's avatar
jwdonal
5 years ago
RTC Battery Type for S10 SoC Dev Kit?
I have a S10 SoC Dev Kit. I’d like to use the onboard RTC for keeping proper time in Linux between power cycles. However, I don’t know which battery type is required in the BT1 slot on the board. I i...
  • AR_A_Intel's avatar
    5 years ago
    Hi
    Based on my understanding, most dev kit using (Energizer 357-303HVZ Lithium coin battery) https://data.energizer.com/pdfs/357-303ZB.pdf
    You should be able to find the existing battery full part number (to clarify the spec) from dev kit BOM list. Example below is the BOM list path from dev kit installer
    • stratix10_1sx280uf50 >> board_design_files >>BOM
