RVadl2's avatar
RVadl2
5 years ago
RSU AN741- Difference between factory_application1.pof and app_image_1
HI,
In the Application Note AN 741, what is the difference between the files factory_application1.pof and app_image_1.pof.
Can I use the below files to test RSU without compiling the projects
factory_application2.pof
Nios_application.pof
Thanks in Advance
  • Hi,
    app_image_1 is the design files while factory_application1.pof is master file that you can used without compiling the design file.
    Yes, factory_application1.pof and other master file in table 3 can be use to test RSU without compiling design file as per mention in AN741.
    rEGARDS,
    Aiman
    • RVadl2's avatar
      RVadl2
      Hi Aiman,
      Thanks for the reply. Are "app1.pof"(in section 1.7.1.2) and "factory_application1.pof" same?
      Ravi
  • Hi,
    Yes, both of the file should be the same.
    Aiman
