RVadl2
5 years agoRSU AN741- Difference between factory_application1.pof and app_image_1
HI,
In the Application Note AN 741, what is the difference between the files factory_application1.pof and app_image_1.pof.
Can I use the below files to test RSU without compiling the projects
- 5 years ago
Yes, both of the file should be the same.
Aiman
NurAiman_M_Intel
5 years agoHi,
app_image_1 is the design files while factory_application1.pof is master file that you can used without compiling the design file.
Yes, factory_application1.pof and other master file in table 3 can be use to test RSU without compiling design file as per mention in AN741.
rEGARDS,
Aiman
RVadl2
5 years agoHi Aiman,
Thanks for the reply. Are "app1.pof"(in section 1.7.1.2) and "factory_application1.pof" same?
Ravi
