lambert_yu
Contributor
2 years agoreceiver error for multi-simplex receivers application (transceiver arria 10)
Hi all, FPGA : 10AX115N2F45E1SG simplex rx count : 16 pin assignment : four channel from 4c, four channel from 4d, four channel from 4e,four channel from 4f. ref clock : single 62.5Mhz f...
ZiYing_Intel
2 years agoHi lambert,
I would suggest you can try to reduce the BER by increasing the amplitude or the main tap. If the suggestion still not working for you, you may refer to link below https://www.rocketboards.org/foswiki/Main/WebHome that got a lot of project that you can refer to.
zying
- lambert_yu2 years ago
Contributor
Hi zying,
Sorry, I could not understand these method? increase amplitude ? TX vod? But from previous message, I mentioned that link is okay when I decrease Vod; What's main tap? DFE or other?
BRs,
Lambert
