lambert_yu
Contributor
2 years agoreceiver error for multi-simplex receivers application (transceiver arria 10)
Hi all, FPGA : 10AX115N2F45E1SG simplex rx count : 16 pin assignment : four channel from 4c, four channel from 4d, four channel from 4e,four channel from 4f. ref clock : single 62.5Mhz f...
ZiYing_Intel
2 years agoHi Lambert_yu,
Can you share me your simulation result? So I can see the things from the signal
zying
lambert_yu
Contributor
2 years agoHi zying,
Which signals will you expect me to provide? The interface signal of transceiver or anyother? Firstly, I will provide 3 transceiver interface signal, please check. If you need more detail, please tell me and I will capture them and provide to you.
Brs,
Lambert
