lambert_yu
Contributor
2 years agoreceiver error for multi-simplex receivers application (transceiver arria 10)
Hi all, FPGA : 10AX115N2F45E1SG simplex rx count : 16 pin assignment : four channel from 4c, four channel from 4d, four channel from 4e,four channel from 4f. ref clock : single 62.5Mhz f...
ZiYing_Intel
2 years agoHi lambert_yu,
I think maybe you need concern about the voltage that you use. It has the minimum and maximum voltage requirement for different usage. For further information, you may refer link below https://www.intel.com/content/www/us/en/docs/programmable/683771/current/transceiver-performance-for-gx-sx-devices.html
zying
- lambert_yu2 years ago
Contributor
Hi Zying,
Now we use chip-to-chip design, and our fpga is 10ax115n2f45e1sg, so I think it's okay for VCCTR_GXB = 1.03v (in the below attached picture), do you think so?
In the previous picture, we mark VCCTR_GXB as 1V, now we had changed it to 1.03v on board now.
BRs,
Lambert
