receiver error for multi-simplex receivers application (transceiver arria 10)
Hi lambert,
cand you share the .qar file? So that I can try debug the issue from my side.
zying
- lambert_yu2 years ago
Contributor
Hi ZiYing,
From our current debug, we found that keep all design as before, and decrease the VOD of TX (1000mv -> 600mv (other value, we have not try), 1.0Gbps/2.0Gbps, other we do not try), there's good performance for the receiver. But on the view of our hardware designer, they think at 1.0Gbps, tx should not lead to so large effect on the receiver when Vod at 1000mv. They think from the eye diagram after ac-coupling capacitance, it's sufficient for RX to receives data correctly.
I could not provide related design for you, but I will provide related parameter and application framework next.
BRs,
Lambert
Contributor
Hi ZiYing,
The attached is the related configuration pictures and connection framwork. Please check, thanks.
BRs,
Lambert
