Quartus II Programmer question
I want to program only the FPGA (no HPS, NIOS2, or EPSC) with a simple program, so I set MSEL to 10010. I expect the program to be gone after any power-recycle which is ok for now.
I clicked Auto-detect, it found:
1- SOCVHPS
2- 5CSEBA6
At this point the Start/Stop buttons are still disabled.
So, I clicked "add file", and added the .sof file. Now I see:
TDI --> SOCVHPS --> 5CSEBA6 --> 5CSEBA6U23 --> TDO
I deleted the SOCVHPS, since I do not need HPS for now, and here is what I see: TDI --> 5CSEBA6 --> 5CSEBA6U23 --> TDO
It did program successfully, and the program worked as expected, and I did lose the program after any power recycle.
What I do not understand is:
What does this mean: TDI --> 5CSEBA6 --> 5CSEBA6U23 --> TDO
If 5CSEBA6U23 is the program, and 5CSEBA6 is the Cyclone V device, then how come the device is programming the program ?
I am very new, and I really do not understand who is programming who.
Thanks for any help.
- Cyclone devices are designed such that JTAG instructions have precedence over any device operating modes. i.e If you attempt JTAG configuration in Cyclone FPGAs during non-JTAG configuration, non-JTAG configuration is terminated and JTAG configuration is initiated.
- To configure a single device in a JTAG chain, the programming software places all other devices in BYPASS mode. In BYPASS mode, devices pass programming data from the TDI pin to the TDO pin through a single bypass register without being affected internally. This scheme enables the programming software to program or verify the target device.
- Removing Device from GUI does not mean we have physically removed it will only BYPASS in both the case.
- to remove device physically from device chain look into cyclone v soc development kit JTAG Chain Control DIP Switch signal "HPS_JTAG_EN " for example.
Hope it helps.
Kindly refer cyclone V configuration hand book for more information.
Anand
- AnandRaj_S_Intel
Hope it helps.
Anand
- imarz1
Thank you.
