imarz1
7 years agoQuartus II Programmer question
I want to program only the FPGA (no HPS, NIOS2, or EPSC) with a simple program, so I set MSEL to 10010. I expect the program to be gone after any power-recycle which is ok for now. I clicked Auto-de...
- 7 years ago
- Cyclone devices are designed such that JTAG instructions have precedence over any device operating modes. i.e If you attempt JTAG configuration in Cyclone FPGAs during non-JTAG configuration, non-JTAG configuration is terminated and JTAG configuration is initiated.
- To configure a single device in a JTAG chain, the programming software places all other devices in BYPASS mode. In BYPASS mode, devices pass programming data from the TDI pin to the TDO pin through a single bypass register without being affected internally. This scheme enables the programming software to program or verify the target device.
- Removing Device from GUI does not mean we have physically removed it will only BYPASS in both the case.
- to remove device physically from device chain look into cyclone v soc development kit JTAG Chain Control DIP Switch signal "HPS_JTAG_EN " for example.
Hope it helps.
Kindly refer cyclone V configuration hand book for more information.
Anand
AnandRaj_S_Intel
7 years agoHi,
Hope it helps.
Anand
imarz1
7 years agoThank you.
