AleCampla's avatar
AleCampla
6 years ago
QSFP module on Stratix10 MX dev kit
Hi
I am trying to have a 1Gbit Ethernet communication between my laptop and the S10 MX devkit, over QSFP.
I already have the RJ45 to QSFP converters connectors, and I have (hopefully) configured well the PHY and MAC IPs.
Spying on the GMII signals I can't see anything arriving: valid signal from PHY to MAC remains at zero when I send ping requests. The ping is done from the linux PC specifing the right port where the Eth cable is connected to the FPGA. And on the PC side I see Host Unreachable.
Question: is the QSFP connector enabled by default? Is there a way to check that?
In theory the Board System Tool should show a tab dedicated to QSFP. But When the S10 MX devkit is connected via Jtag, I can't access that specific tab.
Let me know if you have suggestions.
Thanks and best regards,
Alessandra
