QSFP module on Stratix10 MX dev kit
- 6 years ago
Hi Alessandra,
Sorry for late respond.
Dev kit BTS software required user to use the exact Quartus version as specified in dev kit web site to avoid software compatibility issue.
- I can see you are using v19.2 while dev kit website is advertising Quartus version which is either v18.1.1 or v18.1.2
- https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-s10-mx.html
Another suggestion for you is you can cross check with Intel FPGA example design that utilize 10G MAc and Multirate PHY IP as well. checkout below design example
The only catch is the example design is developed to work on another Intel FPGA S10 SI kit board, not S10 MX dev kit but it's still a good reference for you.
dlim
Hi Alessandra,
dlim
- AleCampla6 years ago
Hi dlim,
thanks for your reply!
Regarding the quartus version, ok I think there I can't do much.
But thanks for the other document, I'll for sure take a look at that
Cheers,
Alessandra
