SATC's avatar
SATC
6 years ago
Programming the Image Core: Error - quartus_cvp is not recognized as an internal command.
I'm trying to connect the Intel Cyclone 10 GX device to PCIe. When I execute the command described in the Intel manual:
quartus_cvp --vid=<Vendor ID> --did=<Device ID> xxx.core.rbf
The terminal presents me the following error:
'quartus_cvp' is not recognized as an internal command
or external, an operable program or a batch file.
  • Hi,
    After further checking, it looks like quartus_cvp is no longer supported. Sorry for the inconvenience.
    Could you try to restart your PC again and try to performed "cp <filename>.core.rbf /dev/altera_cvp"? I suspect that the PCIe link might be in used which cause the issue.
  • JohnT_Altera's avatar
    JohnT_Altera
    • thanhle's avatar
      thanhle
      Hi JohnT_Intel,
      How should I perform Core Image update without installing Intel Quartus Prime ?
  • SATC's avatar
    SATC
    Okay john, it worked.
    But now, I have another problem. The data visualization is done through / dev / Alter_cvp, right? but I can't open this file, how should I proceed?
    JohnT_Altera
    The altera_cvp is used for CvP usage only. You will need to write your own driver to send the data to the PCIe end point.
  • SATC's avatar
    SATC
    John,
    I believe that the users of the FPGA Cyclone 10 GX card must have already started the projects with the use of PCI, would you know to indicate me a person, question in this forum or a tutorial in pdf of the alteration that guides the development of the PCIe endpoint?
    JohnT_Altera
    I would recommend you to look at the altera_cvp.c code to understand how we are using the it to access the VSEC register.
    • SATC's avatar
      SATC
      Ok, and about the other question, Can you recommend me some material?
  • SATC's avatar
    SATC
    John, thank you very much for your attention.
    Tomorrow I going to study this material and any questions, get in touch.
