SATC
6 years agoProgramming the Image Core: Error - quartus_cvp is not recognized as an internal command.
I'm trying to connect the Intel Cyclone 10 GX device to PCIe. When I execute the command described in the Intel manual: quartus_cvp --vid=<Vendor ID> --did=<Device ID> xxx.core.rbf The terminal pr...
- 6 years ago
After further checking, it looks like quartus_cvp is no longer supported. Sorry for the inconvenience.
Could you try to restart your PC again and try to performed "cp <filename>.core.rbf /dev/altera_cvp"? I suspect that the PCIe link might be in used which cause the issue.
SATC
6 years agoSo, as I understand it from this tutorial https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_c10_cvp.pdf
the verification of cvp registers must be done through this file. How can I check the VSEC Registers of CvP status?
