PCIe design example for Arria10 SX
Any of you familiar with the PCIe design example for Arria10 to help me with the following?
I generated two PCIe design example for Arria10 SX for two different boards (with different Arria10 SX part numbers) using Quartus pro 18.1. I see the following:
- both design pass the simulation test.
- both design fail the same way on HW test. The test shows that read back data is FFFFFFFF, not ABCD1234 as expected.
I use signal tap to look into the rx_st and tx_st buses and I see something strange:
- there is never any activity on the tx_st bus, i.e no tx_st_valid, tx_st_sop, tx_st_eop, tx_st_data.... in other words, there is no data coming back to the host.
- I see some invalid data cycle on rx_st bus, i.e. I see rx_st_valid high but rx_st_sop low and/or rx_st_eop low.
- Once in a while, I see a read cycle on rx_st_data with the data pattern ABCD1234. The read command on rx_st bus (from host to FPGA) should not have any data pattern. Read data should return on the tx_st bus (from FPGA to host). It looks like this is a write command but it is corrupted and becomes a read command.
- Sometime is see an invalid write command with poison bit =1. It looks like a write command is corrupted.
I use Avalon ST, PCIe gen2/3 x4, 64 bit, 250Mhz. The design example seems to target the Arria10 GX development board but I think it should work with Arria SX part on my board since there is no error when i compile for Arria10 SX.
I only have the signals for PCIe bus between the FPGA board and the host. I don't have any of those signals that are available for Arria10 GX development board. This should not be a problem, should it?
Let me know if you want to see some of the waveform on rx_st and tx_st bus. I can capture them and share with you.
Thank you for your help.
- DNguy4
- SengKok_L_Intel
Hi Sir, If the design example from AN456 work for you? https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an456.pdf Regards -SK - DNguy4
SK Lim,
AN456 does not help. I followed the document in the link below to generate the example design and it failed as I described in the post.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-dex-a10-pcie-avst.pdf
Do you know if it works with Arria10 SX or does it work with Arria10GX only?
- SengKok_L_Intel
Hi Sir,
Yes, the AN456 and generated example design has tested using A10 GX development kit. I don't see why it can't work for SX device.
What driver you are using? Linux or window? Is this a custom board? I would suggest to add the "ltssm" signal in signaltap to confirm it can get a stable L0, and the "lane_act", and "currentspeed" are all expected.
Regards -SK
- DNguy4
- DNguy4
SK Lim,
I use the following board and I see the same problem:
- Intel development board with Arria10 SX 10AS066N3F40E2SG: https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/arria-10-soc-development-kit.html
- Reflexces Alaric board with Arria10 SX 10AS066H3F34I2SG
https://www.reflexces.com/intel-fpga/arria-10-intel-fpga/alaric-instant-devkit-arria-10-soc-fmc-idk
I don't have any Arria10 GX board to try.
- DNguy4
- DNguy4
SK Lim,
I forgot to mention that I use the windows 10 driver and the test program that comes with Quartus 18.1 Pro.
Attached is the zip file containing the driver and test program.
- DNguy4
I found the cause of the problem. I need to terminate NPOR signal properly to get it to work.
- SengKok_L_Intel
Thank you for the update.
Yes, you need to set the Npor to "1" if this is not used.
Regards -SK
