pac n3000 8x10G failed to connect with 40G server net card with 1x40G optical module and fiber
server_n3000( pac 8x10G)<---1X40G optical module and fiber--->Server40GbE , led lights on Server40GbE
are out, while the led lights is on when use the same optical module and fiber to connect the two ports within Server40GbE
- JonWay_altera
When you connect the 1x40G cable to the N3000. what is the output of fpgainfo phy? UP or DOWN?
- fzhan51
I just found that result changes all the time,
e.g.1 e.g.2 e.g.3
Port0 10G : Up : Up : Down
Port1 10G : Down : Up : Down
Port2 10G : Down : Up : Down
Port3 10G : Down : Up : Down
Port4 10G : Down : Down : Down
Port5 10G : Up : Up : Up
Port6 10G : Up : Up : Up
Port7 10G : Down :Down :Down
- JonWay_altera
Hi @fzhan51 , When you say 1x40G, it is only 1 port at 40G, right?
Or, Do you mean 4x10G instead? Because the the card can only support 10G per port.
- fzhan51
Port0 10G : Down
Port1 10G : Down
Port2 10G : Down
Port3 10G : Down
Port4 10G : Down
Port5 10G : Up
Port6 10G : Up
Port7 10G : Down
Retimer A Version : 101c.1064
Retimer B Version : 101c.1064
