pac n3000 8x10G failed to connect with 40G server net card with 1x40G optical module and fiber
When you connect the 1x40G cable to the N3000. what is the output of fpgainfo phy? UP or DOWN?
I just found that result changes all the time,
e.g.1 e.g.2 e.g.3
Port0 10G : Up : Up : Down
Port1 10G : Down : Up : Down
Port2 10G : Down : Up : Down
Port3 10G : Down : Up : Down
Port4 10G : Down : Down : Down
Port5 10G : Up : Up : Up
Port6 10G : Up : Up : Up
Port7 10G : Down :Down :Down
- JonWay_altera6 years ago
Hi @fzhan51 , When you say 1x40G, it is only 1 port at 40G, right?
Or, Do you mean 4x10G instead? Because the the card can only support 10G per port.
- fzhan516 years ago
1 port at 40G , 4X10G fiber test sucess. now I am confused.
1 port at 40G --> it makes sense it will FAIL because the card supports 10G per port
4 port at 10G each --> it makes sense it will PASS because the card supports 10G per port
Im not sure there is such cable as 1 port at 10G --> then this will further confirm my explanation.
Btw, 1x40G is NOT EQUAL to 4x10G !!
