gustifix2
2 years agoOneAPI for Agilex 7 I-Series Dev Kit: build-default-binaries.sh fails
Hello! I am following https://ofs.github.io/ofs-2024.2-1/hw/common/user_guides/oneapi_asp/ug_oneapi_asp/ to set up OneAPI for the Agilex 7 I-Series Development Kit (2x R-Tile, 1x F-Tile). At step 2...
BoonBengT_Altera
Moderator
1 year agoHi @gustifix2,
Thank you for waiting and the patients.
After discussing this internally with our IP team, since the error are mentioning the fitter problem and we have unused pin. Hence we should remove them with the correct pin constraint.
It should work per the example design which requires 2x8gb external memory.
Hope that clarify.
Best Wishes
BB
