AJuba's avatar
AJuba
7 years ago
Not Able to Detect CAN Bus on my system
Hello support.
I am not able to detect my CAN bus on my custom board,
this is Cyclone 5 soc device.
Please help.
  • hello AJuba,
    This might fall within 2 reasons:
    1- the CAN bus is not enabled in device tree. to enable this, you need to modify the dts file, it might be something like this:
    can0: can@ffc00000 {
    compatible = "bosch,d_can";
    reg = <0xffc00000 0x1000>;
    interrupts = <0 131 4>, <0 132 4>, <0 133 4>, <0 134 4>;
    clocks = <&can0_clk>;
    status = "disabled";
    can1: can@ffc01000 {
    reg = <0xffc01000 0x1000>;
    interrupts = <0 135 4>, <0 136 4>, <0 137 4>, <0 138 4>;
    clocks = <&can1_clk>;
    both status="disabled" should be enabled if you have 2 CAN buses.
    2- Make sure to enable CAN bus driver in Linux Kernel menuconfig.
    -> Networking Support
    -> <*> CAN Bus Subsystem Support
    -> <*> Raw CAN Protocol
    -> <*> Broadcast Manager CAN Protocol
    -> <*> CAN Gateway/Router
    CAN Device Drivers
    -> <*> Platform CAN drivers with Netlink support
    -> [*] CAN bit-timing calculation
    -> <*> Bosch C_CAN/D_CAN Devices
    -> <*> Generic Platform Bus based C_CAN/D_CAN Driver
    -> [*] CAN devices debugging messages
    Hope this might help.
  • FawazJ_Altera's avatar
    FawazJ_Altera
    hello AJuba,
    CAN Device Drivers
    • Eneko's avatar
      Eneko
      Hello. We have manged to make CAN0 and CAN1 working but we have a problem with the bus speed. We are getting 3 around 39 kbit/s when configuring 125 kbit/s.
      Although we have 100Mhz clock configured in Preloader and registers in the clock manager, system reports 40Mhz when listing driver configuration (ip -d -s link show can0).
      If we force driver to read 100Mhz clock, we get 15.625 kbit/s, this is, 8 times slower than expected.
      If we force driver to read 12.5Mhz clock, we get correct bus speed.
      The same is hapening with CAN1.
  • AJuba's avatar
    AJuba
    Hello FJumaah,
    Wow amazing....
    Thanks for your help.​ I was able to solve my problem by following item 1.
