Not Able to Detect CAN Bus on my system
- 7 years ago
hello AJuba,
This might fall within 2 reasons:
1- the CAN bus is not enabled in device tree. to enable this, you need to modify the dts file, it might be something like this:
can0: can@ffc00000 {
compatible = "bosch,d_can";
reg = <0xffc00000 0x1000>;
interrupts = <0 131 4>, <0 132 4>, <0 133 4>, <0 134 4>;
clocks = <&can0_clk>;
status = "disabled";
can1: can@ffc01000 {
reg = <0xffc01000 0x1000>;
interrupts = <0 135 4>, <0 136 4>, <0 137 4>, <0 138 4>;
clocks = <&can1_clk>;
both status="disabled" should be enabled if you have 2 CAN buses.
2- Make sure to enable CAN bus driver in Linux Kernel menuconfig.
-> Networking Support
-> <*> CAN Bus Subsystem Support
-> <*> Raw CAN Protocol
-> <*> Broadcast Manager CAN Protocol
-> <*> CAN Gateway/Router
CAN Device Drivers
-> <*> Platform CAN drivers with Netlink support
-> [*] CAN bit-timing calculation
-> <*> Bosch C_CAN/D_CAN Devices
-> <*> Generic Platform Bus based C_CAN/D_CAN Driver
-> [*] CAN devices debugging messages
Hope this might help.
hello AJuba,
CAN Device Drivers
Hello. We have manged to make CAN0 and CAN1 working but we have a problem with the bus speed. We are getting 3 around 39 kbit/s when configuring 125 kbit/s.
Although we have 100Mhz clock configured in Preloader and registers in the clock manager, system reports 40Mhz when listing driver configuration (ip -d -s link show can0).
If we force driver to read 100Mhz clock, we get 15.625 kbit/s, this is, 8 times slower than expected.
If we force driver to read 12.5Mhz clock, we get correct bus speed.
The same is hapening with CAN1.
