NIOS Processor does not boot using QSPI Flash.
I am trying to boot Nios II Processor from QSPI Flash on MAX10 dev kit.
For that I have prepared one design that blink one LED via software(.hex).
I performed all the steps mentioned in AN 730: Nios II Processor Booting Methods in MAX 10 FPGA Devices for Option 5. But not able to blink the LED[0] on Power Cycle after programming the HEX File into QSPI Flash.
Attached document for steps that I have performed for reference. Also attached .zip file of the QSYS design & NIOS Project.
Please share your feedback.
- KellyJialin_Goh
Any updates on the booting of the QSPI flash after changing the hardware design? Here is the link for your reference from the previous post to change the IP just in case you missed out: https://www.intel.com/content/www/us/en/docs/programmable/683689/current/processor-application-copied-from-general.html
Thank you.
Kelly
- himanshuvaria
I have not yet tried to boot QSPI flash using general_serial_flash_interface_0 in the hardware design as I am busy with some other work right now. I will surely try to build the design using general_serial_flash_interface_0 as soon as I am done with my work.
I will keep you updated after trying the suggestion you provided.
Thank You for the feedback.
Himanshu
- KellyJialin_Goh
Any updates from your side?
Kelly
- himanshuvaria
As suggested by you I have tried to boot MAX10 DEVICE by using general_serial_flash_interface_0 in my design. Still I am facing the same issue. The NIOS Processor does not boot. I have referred the following document for using general_serial_flash_interface_0:
Kindly give your feedback for the root cause of this issue.
Thank You,
Himanshu
- KellyJialin_Goh
You have to download a PFL(Parallel Flash Loader) project to program the QSPI flash. For more info please check: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
I will share with you an example of the MAX10 QSPI boot and the PFL(Parallel flash programmer), use this project .sof file to program the FPGA to work as a bridge to the flash. Then choose the design .pof file to program the flash then reset the board to boot from the flash successfully.
Thank you.
Kelly
- KellyJialin_Goh
- KellyJialin_Goh
- KellyJialin_Goh
Any updates from your side after downloading the Parallel Flash Loader(PFL)? Can it flash now?
Kelly
- himanshuvaria
I am already being able to download the hex(.pof) file in the QSPI Flash by running the sof of Parallel Flash Loader Project into the MAX10 Dev Board. I have no issues in detecting the QSPI Flash and programming it in the programmer.
The issue here is that after programming the QSPI Flash the NIOS Processor does not boot on Power Cycle as per requirements.
You can further give your feedback on this issue.
Himanshu
- KellyJialin_Goh
Greetings,
Hope we have clarify your doubts. May I set this case to close pending? You may reopen a new case on further issues that you encounter on our forum and we will be happy to help.
Thank you.
Kelly
- himanshuvaria
No, I am still not being able to boot the NIOS Processor after downloading the hex(pof) in QSPI Flash. All the feedback provided by you has been looked after but the outcome is still the same.
Himanshu
- KellyJialin_Goh
I see that the flash device you use from the Dev kit is N25Q512A83. Unfortunately, the flash chip GD25Q16 is not supported. The supported flash devices for configuration memory are, EPCQ, EPCQ-A, EPCQ-L, and Micron* MT25Q (256Mb to 2Gb) devices, therefore QSPI flash will not boot.
Thank you.
Kelly Jialin, GOH
- KellyJialin_Goh
Can I kindly get an update or confirmation from your side as soon as possible? Your help is very much appreciated.
Thank you.
Kelly
- KellyJialin_Goh
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
Thank you.
Kelly Jialin, GOH
