NIOS Processor does not boot using QSPI Flash.
Greetings,
Hope we have clarify your doubts. May I set this case to close pending? You may reopen a new case on further issues that you encounter on our forum and we will be happy to help.
Thank you.
Kelly
No, I am still not being able to boot the NIOS Processor after downloading the hex(pof) in QSPI Flash. All the feedback provided by you has been looked after but the outcome is still the same.
Himanshu
- KellyJialin_Goh3 years ago
I see that the flash device you use from the Dev kit is N25Q512A83. Unfortunately, the flash chip GD25Q16 is not supported. The supported flash devices for configuration memory are, EPCQ, EPCQ-A, EPCQ-L, and Micron* MT25Q (256Mb to 2Gb) devices, therefore QSPI flash will not boot.
Thank you.
Kelly Jialin, GOH
