14 years ago
Max V Clocks
When using the Max V CPLD Dev Board, is there access to use the on board clocks as a resource?
There's a 10MHz (MaxV clock), 6MHz (usb) and a 24MHz xtal on the board, but I dont see these appearing anywhere in the documentation as clocks that can be used.
I can always connect an external clock connection but seems odd the ones already there cant be used.
1 Reply
    The reference manual clarifies that the 10 MHz clock is directly driving the MAX V but doesn't list the pin number.
    The information can be found however both in the schematic diagram as well as in the pin assignments of the example designs.
    set_location_assignment PIN_H5 -to CLK_SE_AR
