Mandelbrot viewer on Cyclone V - Platform Designer layout
You can do this...
NOTE 1: when you set 0x0, then you access this device from the HPS using the address 0xC000_0000 (you are accounting for the offset of the FULL bridge, plus the base address of your device). This is the access point to your "data"
NOTE 2: "in-crs" can also be connected to the Full Bridge, this is the access for the "control registers" of the "FIFO IP" see:
https://docs.altera.com/r/docs/683130/25.3/embedded-peripherals-ip-user-guide/functional-description?tocId=z_fqMkXoilssdb5huYtRzg
When you connect this, it will require an address. Again, when using the HPS to access the cotrol registers you need the address = 0xc000_0000 (full bridge) + <BASE defined by you>
NOTE3: The "out" is already a "avalon streaming interface". I asumme you IP already has a "Avalon streaming receiver". Maybe this receiver is the "sink" you are poiting out, but I dont know this IP (It is not supported by us)
I cannot comment in further connections to custom IP, I can only help you with generic Platform Designer and Quartus questions. If you use Altera IP, most documentation is available and you can find the list of control registers to configure them.
Good luck with your project.
~E.V.
Thank you very much for your replies and assistance. I think I might be getting closer.
A big part of what I'm trying to find out but didn't manage to, is whether or not a custom component is even needed. I'm writing again all of the communication that has to be done:
HPS --> FPGA: FIFO, and then messages "pulling" off of the FIFO using the avalon streaming interface
FPGA --> HPS: SDRAM (which is external to the FPGA).
1. In the most general case, to implement this kind of communication, does this necessarily require a custom module that has the verilog source file/files included in it?
from what I understand from the workflow, there are two methods when working with Platform Designer: the first one, which is the one I thought was more common, is to make the layout wiring and address mapping in the gui, export conduits, and then use the auto generated code to tie these conduits to logic in the verilog source code.
the second one, which i'm less familiar with and trying to understand if necessary in this case, is creating a new custom component add adding files to it, use the "analyze synthsis files" and make the gui wiring.
2. Addition information: it's mentioned that: "The FIFO instantiated on the FPGA, along with the Avalon bus structure and SDRAM controller that we used, were all Altera". I take this as supporting the first kind of workflow - without a custom component. Does this make sense? if so, please help me figure out the layout, because I've really been trying all my best and couldn't figure it out for several weeks.
In order to add a SDRAM controller, i went to an older quartus version (20.1 because the SDRAM Controller Intel FPGA IP seems to no longer be supported with 24.1 and doesn't appear in the catalog):
Please note that:
the "out" interface of the fifo couldn't be wired to anything in the screenshot above if there was no sink in the entire design to accept it. So what I did, is add a new custom component but only because i didn't know what altera IP i should use. As I explained above, when searching in the catalog, i didn't find the right thing, maybe i'm wrong? attaching again:
all the options below, which were cut out from the screenshot, are non standard too.
This "custom component" of mine has nothing to do with my verilog source code, no files added in it. It only includes simple three interfaces: clock, reset and avalon_streaming_sink:
in order to accept the fifo_0.out source.
3. Do you think that the platform designer layout shown above should be sufficient to implement the communication of the problem described in the beginning of this message? what do i need to know about setting the base address and span of the SDRAM Controller component as a slave on the h2f axi master?
Thank you very much
- EstebanVV_Altera8 months ago
Answering your questions.
-- Regarding 1: Yes, at you said there are two options for you to included a custom IP into your design (a collection of Verilog files)
a. "Wrapping" the IP in a structure that can be instantiated by Platform Designer, following
https://docs.altera.com/r/docs/683609/25.1.1/quartus-prime-pro-edition-user-guide-platform-designer/creating-platform-designer-components and How To Create A Custom Platform Designer Component That Uses Intel IP Components | Altera Community
b. As you said, you can export the interfaces from PD of other IP and make it visible to the <top_level> HDL file. Then use pure HDL language to connect your system.
-- Regarding 2: The SDRAM controller is not longer supported by standard. Please see: https://community.altera.com/discussions/boards-and-dev-kits/de10-lite-and-sdram-controller-ip/348588
(It is always a good idea to search in the forum for issues, as they might be already documented)
" the "out" interface of the fifo couldn't be wired to anything in the screenshot above if there was no sink in the entire design to accept it." : well, I don't know your IP... but from what you have been telling me, your IP should have a streaming interface that "accepts" the streaming interface output from the FIFO
I think what you are missing is this "A request distributor then pulls the message off of the FIFO using the avalon streaming interface, and either sends it, one word at a time, to an unoccupied tile solver or waits if they are all occupied."
Again, I don't know your design, BUT "request distributor" is the key word. Is this something you have to implement? is this included in your source files? This is not certainly an IP provided by Altera.
--- Regarding 3. Your layout seems ok. But keep in mind your software, as It might have the addresses already in place and expected for each device.
~E.V.
- KianHinT_altera7 months ago
Dear Customer,
As there are no further inquiries, I will transition this thread to the community to assist with any future follow-up questions.
Altera Technical Support
