TGao's avatar
TGao
6 years ago
JTAG can't connect sometime
Dear Sir/Madam,
Jtag cant't connect sometime , and error hint below:
​Ted.Gao
  • YuanLi_S_Intel's avatar
    YuanLi_S_Intel
    Hi Ted,
    There are few possibility that causes this error, can you check the following?
    [1] Can you check if you are selecting the correct configuration scheme, device OPN in Quartus design?
    [2] Can you change TCK frequency to 6MHz?
    Thank You.
    Bruce.
    • TGao's avatar
      TGao
      Hi SooY, 1. The OPN is correct 2. I use usb blaster ,can’t change the frequency. Ted
    YuanLi_S_Intel
    Hi Ted,
    Can you please elaborate further so that i can get a full picture on this scenario?
    May i know what configuration scheme you are using? Have you tried to program with a SOF file? When you mention about sometimes JTAG cant connect. What does this mean? Please elaborate.
    Thank YOu
    • TGao's avatar
      TGao
      Hi SooY Solved, Thanks. Ted.Gao
    YuanLi_S_Intel
    Hi Ted,
    Oh, i am glad it helps. May i know what did you do to make it work? Perhaps we can help the community in this forum as well.
    Thank You.
    Bruce
    • TGao's avatar
      TGao
      Hi SooY, The welding of the plate is not very good. After re welding, the problem is solved. Ted.Gao
    YuanLi_S_Intel
    Hi Ted,
    Thanks for your sharing. Hopefully it helps the community here. I am closing this thread. Please rate me good if my support is good.
    Thank You.
