TGao
6 years agoJTAG can't connect sometime
Dear Sir/Madam, Jtag cant't connect sometime , and error hint below: Ted.Gao
YuanLi_S_Intel
6 years agoHi Ted,
There are few possibility that causes this error, can you check the following?
[1] Can you check if you are selecting the correct configuration scheme, device OPN in Quartus design?
[2] Can you change TCK frequency to 6MHz?
Thank You.
Bruce.
- TGao6 years ago
Hi SooY, 1. The OPN is correct 2. I use usb blaster ,can’t change the frequency. Ted
