Issue with HPS Reset Not Responding in Agilex 7 (AGFB014R24B) Powered via MAX 10 CPLD
Hi all,
I am currently working with the Agilex 7 series FPGA, part number AGFB014R24B, which is powered up through a MAX 10 CPLD IC via power sequencing.
The MAX 10 CPLD is responsible for enabling the voltage regulators and powering up the main power supply for the Agilex 7 FPGA. I have followed the power-up sequencing order as recommended by Intel, and also referred to two development kits that use the same Agilex 7 FPGA and MAX 10 CPLD-based power-up mechanism.
All voltage regulators were verified to be providing the correct outputs before proceeding.
After successfully powering up the Agilex 7 device using the MAX 10 CPLD, I observed in the Configuration Debugger → Device Info that the HPS reset signal is not responding—it is neither high nor low.
Below are the current configuration pin assignments from the tool settings:
PWRMGT_SCL → SDM_IO0
PWRMGT_SDA → SDM_IO12
CONFIG_DONE → SDM_IO16
HPS_COLD_nRESET → SDM_IO13
Configuration Clock Source → 125 MHz
Could anyone please advise if this configuration is correct and what might cause the HPS_COLD_nRESET signal to not toggle or respond?
Thanks in advance.
1 Reply
- Farabi_Altera
Can you open Quartus Programmer Tools > Configuration Debugger
What you see in the Configuration Status? If you see BOOTROM, meaning you stuck in SDM before configuration.
regards,
Farabi
