Is Signal probe option not available within Quartus 19.3 pro? I used it in the past as explained by an Altera Engineer, but can't find it anymore. https://www.youtube.com/watch?v=20WwtqaA1dY
- RichardT_altera
Hi, you can refer to the document below on the guidelines in using the signal probe:
Intel® Quartus® Prime Pro Edition User Guide: Debug Tools
Let me know if it helps.
- AEsqu
Contributor
Thanks Richard.
So the GUI has been removed and I will have to edit the qsf or tcl.
Any reason why the GUI was removed?
- AEsqu
Contributor
Richard,
I followed the doc and this seems to be not supported anymore (CONNECT_SIGNAL_PROBE_PIN is not in the list anymore):
In .qsf:
set_global_assignment -name CREATE_SIGNALPROBE_PIN kaya_r_io_D1
in quartus .tcl:
set_instance_assignment -name CONNECT_SIGNAL_PROBE_PIN kaya_r_io_D1 -to rfd_ic_i|u_top|u_core|u_atlas|A_flexcomm_array[3].A_flexcomm|A_flexcomm|A_minuart_gen.A_minuart_core|div_inst|clk_div_inst|z_mux_inst|z
ERROR: Illegal assignment name: CONNECT_SIGNAL_PROBE_PIN. Specify a legal assignment name. To view the list of legal assignment names, run "get_all_assignment_names".
BDF_FILE
VECTOR_TEXT_FILE
TEXT_FILE
VHDL_FILE
GDF_FILE
AHDL_FILE
INCLUDE_FILE
VERILOG_FILE
SYSTEMVERILOG_FILE
VERILOG_INCLUDE_FILE
VQM_FILE
EDIF_FILE
C_FILE
CPP_FILE
CPP_INCLUDE_FILE
CUSP_FILE
DSPBUILDER_FILE
ASM_FILE
HEX_FILE
VCD_FILE
MIF_FILE
VECTOR_WAVEFORM_FILE
ZIP_VECTOR_WAVEFORM_FILE
BSF_FILE
SYM_FILE
VECTOR_TABLE_OUTPUT_FILE
LMF_FILE
TCL_SCRIPT_FILE
QUARTUS_STANDARD_DELAY_FILE
QUARTUS_SBD_FILE
QUARTUS_PTF_FILE
CDF_FILE
- AEsqu
Contributor
Ok the doc needs some update, this below was accepted:
set_instance_assignment -to kaya_r_io_D1 -name SIGNALPROBE_SOURCE rfd_ic_i|u_top|u_core|u_atlas|A_flexcomm_array[3].A_flexcomm|A_flexcomm|A_minuart_gen.A_minuart_core|div_inst|clk_div_inst|z_mux_inst|z
All signalprobe accepted keywords from the list:
SIGNALPROBE_ALLOW_OVERUSE
SIGNALPROBE_CLOCK
SIGNALPROBE_NUM_REGISTERS
SIGNALPROBE_SOURCE
SIGNALPROBE_ENABLE
SIGNALPROBE_DURING_NORMAL_COMPILATION
- AEsqu
Contributor
Great, quartus crashes during rapid recompile ...
last messages before the crash:
Info(20273): Intermediate fitter snapshots will be committed because Early Place is being enabled during compilation.
Info(20274): Successfully committed planned database.
Info(12517): Periphery placement operations ending: elapsed time is 00:02:49
Warning(15705): Ignored locations or region assignments to the following nodes
Warning(15706): Node "clk_a10_0" is assigned to location or region, but does not exist in design
Warning(15706): Node "clk_a10_1" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C10" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C13" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C14" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C15" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C16" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C17" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C18" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C9" is assigned to location or region, but does not exist in design
Info(11165): Fitter preparation operations ending: elapsed time is 00:02:04
Problem Details
Error:
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/bsyn_interface/bi_bsyn.cpp, Line: 480
enabled
Stack Trace:
0x44951d: BSYN_CONFIG::BSYN_CONFIG(BSYN_FLOW_TYPE) [clone .cold.1340] + 0x75 (fitter_vpr20kmain)
0x7ab232: BSYN_CONFIG::Init(BSYN_FLOW_TYPE) + 0x62 (fitter_vpr20kmain)
0x7b403: FDRGN_EXPERT::run_vpr(bool, bool, bool, bool, BSYN_FLOW_TYPE) + 0x163 (fitter_fdrgn)
0x882fb: FDRGN_EXPERT::early_place() + 0x7b (fitter_fdrgn)
0x2a44f: fit2_fit_early_place_auto + 0xe9 (comp_fit2)
0x4c942: TclNRRunCallbacks + 0x42 (tcl8.6)
0x13d7f: fit2_fit_early_place + 0x2b9 (comp_fit2)
0x4de7b: TclEvalEx + 0x68b (tcl8.6)
0xf3f0e: Tcl_FSEvalFileEx + 0x25e (tcl8.6)
0xf3ffe: Tcl_EvalFile + 0x2e (tcl8.6)
0x14916: qexe_evaluate_tcl_script(std::string const&) + 0x44c (comp_qexe)
0x19a1c: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x417 (comp_qexe)
0x1a9d5: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x558 (comp_qexe)
0x3922e: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::string const&, std::string const&, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0xed (comp_qcu)
0x41d1c: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x259 (comp_qcu)
0x1d69e: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x6a0 (comp_qexe)
0x4032f2: qfit2_main(int, char const**) + 0x92 (quartus_fit)
0x3ef00: msg_main_thread(void*) + 0x10 (ccl_msg)
0x41114: msg_thread_wrapper(void* (*)(void*), void*) + 0x6e (ccl_msg)
0x11f0c: mem_thread_wrapper(void* (*)(void*), void*) + 0x5c (ccl_mem)
0xc728: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x6d85: thr_thread_wrapper + 0x15 (ccl_thr)
0x41c90: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0x148 (ccl_msg)
0x1ed5d: __libc_start_main + 0xfd (c)
0x402ae5: (quartus_fit)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: Red Hat
OS version: 6
Quartus Prime Information
Address bits: 64
Version: 19.3.0
Build: 222
Edition: Pro Edition
I will try with a full compilation and the command in the qsf:
set_instance_assignment -name SIGNALPROBE_SOURCE rfd_ic_i|u_top|u_core|u_atlas|A_flexcomm_array[3].A_flexcomm|A_flexcomm|A_minuart_gen.A_minuart_core|div_inst|clk_div_inst|z_mux_inst|z -to kaya_r_io_D1
- RichardT_altera
Hi, you can use the example below to test the Signal probe flow. You can then modify the example to debug your current projects.
- RichardT_altera
I do not know the exact reason why the GUI was removed. If GUI is more convenience, I can send a request to the engineering team to add this feature in the future Quartus version.
- AEsqu
Contributor
That's ok, I will edit the qsf file directly now, using the node finder gui to find the points to probe out.
- RichardT_altera
Hi, do you need further help with the signal probe?
- AEsqu
Contributor
Hi Richard,
no, but I would like Intel to update the documentation, it is outdated and incorrect, as I mentioned before.
Have a great Holiday ;-)
- RichardT_altera
Thanks for the constructive feedback. We will review and update the document.
Happy holiday to you too. :)
