Is Signal probe option not available within Quartus 19.3 pro? I used it in the past as explained by an Altera Engineer, but can't find it anymore. https://www.youtube.com/watch?v=20WwtqaA1dY
Great, quartus crashes during rapid recompile ...
last messages before the crash:
Info(20273): Intermediate fitter snapshots will be committed because Early Place is being enabled during compilation.
Info(20274): Successfully committed planned database.
Info(12517): Periphery placement operations ending: elapsed time is 00:02:49
Warning(15705): Ignored locations or region assignments to the following nodes
Warning(15706): Node "clk_a10_0" is assigned to location or region, but does not exist in design
Warning(15706): Node "clk_a10_1" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C10" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C13" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C14" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C15" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C16" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C17" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C18" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C9" is assigned to location or region, but does not exist in design
Info(11165): Fitter preparation operations ending: elapsed time is 00:02:04
Problem Details
Error:
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/bsyn_interface/bi_bsyn.cpp, Line: 480
enabled
Stack Trace:
0x44951d: BSYN_CONFIG::BSYN_CONFIG(BSYN_FLOW_TYPE) [clone .cold.1340] + 0x75 (fitter_vpr20kmain)
0x7ab232: BSYN_CONFIG::Init(BSYN_FLOW_TYPE) + 0x62 (fitter_vpr20kmain)
0x7b403: FDRGN_EXPERT::run_vpr(bool, bool, bool, bool, BSYN_FLOW_TYPE) + 0x163 (fitter_fdrgn)
0x882fb: FDRGN_EXPERT::early_place() + 0x7b (fitter_fdrgn)
0x2a44f: fit2_fit_early_place_auto + 0xe9 (comp_fit2)
0x4c942: TclNRRunCallbacks + 0x42 (tcl8.6)
0x13d7f: fit2_fit_early_place + 0x2b9 (comp_fit2)
0x4de7b: TclEvalEx + 0x68b (tcl8.6)
0xf3f0e: Tcl_FSEvalFileEx + 0x25e (tcl8.6)
0xf3ffe: Tcl_EvalFile + 0x2e (tcl8.6)
0x14916: qexe_evaluate_tcl_script(std::string const&) + 0x44c (comp_qexe)
0x19a1c: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x417 (comp_qexe)
0x1a9d5: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x558 (comp_qexe)
0x3922e: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::string const&, std::string const&, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0xed (comp_qcu)
0x41d1c: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x259 (comp_qcu)
0x1d69e: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x6a0 (comp_qexe)
0x4032f2: qfit2_main(int, char const**) + 0x92 (quartus_fit)
0x3ef00: msg_main_thread(void*) + 0x10 (ccl_msg)
0x41114: msg_thread_wrapper(void* (*)(void*), void*) + 0x6e (ccl_msg)
0x11f0c: mem_thread_wrapper(void* (*)(void*), void*) + 0x5c (ccl_mem)
0xc728: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x6d85: thr_thread_wrapper + 0x15 (ccl_thr)
0x41c90: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0x148 (ccl_msg)
0x1ed5d: __libc_start_main + 0xfd (c)
0x402ae5: (quartus_fit)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: Red Hat
OS version: 6
Quartus Prime Information
Address bits: 64
Version: 19.3.0
Build: 222
Edition: Pro Edition
I will try with a full compilation and the command in the qsf:
set_global_assignment -name CREATE_SIGNALPROBE_PIN kaya_r_io_D1
set_instance_assignment -name SIGNALPROBE_SOURCE rfd_ic_i|u_top|u_core|u_atlas|A_flexcomm_array[3].A_flexcomm|A_flexcomm|A_minuart_gen.A_minuart_core|div_inst|clk_div_inst|z_mux_inst|z -to kaya_r_io_D1
