JÖst0
6 years agoI forgot to connect the CONF_DONE pin to a pull-up so it's floating. This results in that the board will not start-up. Any workaround?
I use a MAX 10 device of type 10M04DCF256. Unfortunately I forgot to connect the CONF_DONE pin to a pull-up so it's floating. This results in that the board start-up if the board is above room temp but it does not start-up below room temp. Is there any workaround that I can do in the software code to allow the FPGA to boot up properly and ignore the status of the CONF_DONE pin?
Best regards
Joakim
1 Reply
- YuanLi_S_Intel
Hi Joakim,
Apologize that there is no software code to do for CONF DONE. It is recommended to connect to a pull up.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/PCG-01018.pdf (Page 5)
YL
