JÖst0's avatar
JÖst0
6 years ago
I forgot to connect the CONF_DONE pin to a pull-up so it's floating. This results in that the board will not start-up. Any workaround?
I use a MAX 10 device of type 10M04DCF256. Unfortunately I forgot to connect the CONF_DONE pin to a pull-up so it's floating. This results in that the board start-up if the board is above room temp b...
