GMogn's avatar
GMogn
6 years ago
I am looking for a modulo n counter with a real reset in vhdl; thank you for your reply .
  • Rahul_S_Intel1's avatar
    Rahul_S_Intel1
    Hi ,
    I will paste the sample counter program for your reference , make changes as per your requirement
    library IEEE;
    use IEEE.NUMERIC_STD.all;
    use IEEE.STD_LOGIC_1164.ALL;
    use IEEE.STD_LOGIC_UNSIGNED.ALL;
    entity scale_clock is
    port (
    clk_50Mhz : in std_logic;
    rst : in std_logic;
    clk_2Hz : out std_logic
    end scale_clock;
    architecture Behavioral of scale_clock is
    signal prescaler : unsigned(23 downto 0);
    signal clk_2Hz_i : std_logic;
    begin
    gen_clk : process (clk_50Mhz, rst)
    begin -- process gen_clk
    if rst = '1' then
    clk_2Hz_i <= '0';
    prescaler <= (others => '0');
    elsif rising_edge(clk_50Mhz) then -- rising clock edge
    if prescaler = X"BEBC20" then -- 12 500 000 in hex
    clk_2Hz_i <= not clk_2Hz_i;
    else
    prescaler <= prescaler + "1";
    end if;
    end if;
    end process gen_clk;
    clk_2Hz <= clk_2Hz_i;
    end Behavioral;
    • GMogn's avatar
      GMogn
      Hi , Thank you for your help, I will adapt this program to my application. Cordialement Gilles MOGNOT Electronic Automotive Manager Engineer GMConcept 22,Allée du Jasmin 95130 FRANCONVILLE Tel : 01.30.72.10.00 Port : 06.07.08.07.51 <mailto:[email protected]> [email protected]
      • GMogn's avatar
        GMogn
        Hello Rahul,
        Have you in bibliotheque a Vhdl converter decimal to Hexadecimal?
        Best regards Gilles
    Rahul_S_Intel1
    Hi Gilles,
    With the above , I am closing the tread if you u have any other questions.
    Rahul S
    Rahul_S_Intel1
    Hi Gilles,
    Thanks for the update , I am sorry to let you know , I am not familiar with french words. So I am assuming bibliotheque as library ( got from google).
    If I am rewriting your question, is there any library to convert VHDL to Hexadecimal .
    In my point of view the conversion of VHDL to binary or machine ( device ) depended is done by the tool which is provided from the Vendors .
  • GMogn's avatar
    GMogn
    Hi Rahul,
    This is a decimal to hexadecimal to Vhdl converter for Quartus 14.1_Max 5
    Best regards Gilles
    Rahul_S_Intel1
    Hi ,
    In my knowledge there is not converter from Decimal to Hexadecimal to VHDL ( Decimal >> Hexadecimal >> VHDL)
    Altera is not providing any tool for the conversion to decimal to VHDL
