I am looking for a modulo n counter with a real reset in vhdl; thank you for your reply .
Hi ,
I will paste the sample counter program for your reference , make changes as per your requirement
library IEEE;
use IEEE.NUMERIC_STD.all;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity scale_clock is
port (
clk_50Mhz : in std_logic;
rst : in std_logic;
clk_2Hz : out std_logic
end scale_clock;
architecture Behavioral of scale_clock is
signal prescaler : unsigned(23 downto 0);
signal clk_2Hz_i : std_logic;
begin
gen_clk : process (clk_50Mhz, rst)
begin -- process gen_clk
if rst = '1' then
clk_2Hz_i <= '0';
prescaler <= (others => '0');
elsif rising_edge(clk_50Mhz) then -- rising clock edge
if prescaler = X"BEBC20" then -- 12 500 000 in hex
clk_2Hz_i <= not clk_2Hz_i;
else
prescaler <= prescaler + "1";
end if;
end if;
end process gen_clk;
clk_2Hz <= clk_2Hz_i;
end Behavioral;
- GMogn6 years ago
Hi , Thank you for your help, I will adapt this program to my application. Cordialement Gilles MOGNOT Electronic Automotive Manager Engineer GMConcept 22,Allée du Jasmin 95130 FRANCONVILLE Tel : 01.30.72.10.00 Port : 06.07.08.07.51 <mailto:[email protected]> [email protected]- GMogn6 years ago
Hello Rahul,
Have you in bibliotheque a Vhdl converter decimal to Hexadecimal?
Best regards Gilles
