16 years ago
HSMC interface IO in SOPC Builder
I have a Cyclone III Starter kit, and I want to write some datas in dr_sdram memory from HSMC IO.
In SOPC Builder, how do I build this interface HSMC IO( LVDS format) ?
Do I use the RapidIO megacore or GPIO ?
    --- Quote Start ---
    int main(void)
    int buttons;
    MenuHeader();
    while (1)
    buttons = IORD_ALTERA_AVALON_PIO_DATA(BUTTON_PIO_BASE);
    IOWR_ALTERA_AVALON_PIO_DATA(PIO_BASE,0x08);
    IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,buttons);
    return (0);
    --- Quote End ---
    My Nios'code: PIO_BASE is the hsmc output.
    Check that you assigned the ports to the correct FPGA pins on the pin planner.
    You can also use a signaltap probe on the ports that you added to check if you are setting them to the correct value. From the code that you posted. it seems that you do.
