16 years agoHSMC interface IO in SOPC Builder
I have a Cyclone III Starter kit, and I want to write some datas in dr_sdram memory from HSMC IO. In SOPC Builder, how do I build this interface HSMC IO( LVDS format) ? Do I use the RapidIO m...
16 years agoCheck that you assigned the ports to the correct FPGA pins on the pin planner.
You can also use a signaltap probe on the ports that you added to check if you are setting them to the correct value. From the code that you posted. it seems that you do.
