how to test FPGA PAC N3000 network port
FPGA PAC N3000, configed in 8x10G mode, attached to the Xeron serverA with pcie x16 。we got 40GbE servrB/ 10GbE serverC , QSFP+40G SR-L optical module and 12core mo3 fiber。test case:1) serverA-->one port QSFP and fiber--> serverB: leds out 2)serverA(B)-->one port to another port-->serverA(B);leds on
(a).should we puchase E40GQSFPSR to displace QSFP+40G SR-L? (b)give some advices.
by the way,I didn't enable Vx-Tx Vx-d(not found in the bios),may it help? thanks a lot
- fzhan51
Dear JwChin I would try it.note that, Retimer A/B Version are zero after "rsu bmcimg <BDF>", and port0-7 all Down now even connect the fiber. if it become Porduct version,it can't revert back to Alpha Version,isn't it ? if no, it means that I have to sign the image first
- fzhan51
Dear JwChin I would try it . note that Retimer A/B Version become 0000.0000, port0-port7 always Down after "rsu bmcimg <BDF>". if it become product version,cant it revet to Alpha version ? last time i try the $ sudo super-rsu /usr/share/opae/n3000/one-time-update/<25G or 10G>/\
rollback-*.json --with-rsu in section "B.1.2. Root Entry Hash Not Programmed",if failed. that means I do have to prepare signed image?
- JonWay_altera
Hi @fzhan51 Unfortunately, no you cannot revert from Production to Alpha.
- fzhan51
Dear JwChin,I switch the kernel to 4.19.8; and tried the section "B.1.2.",attached the log.
I remember that I didn't get any signed image,and the last operation i follow to do is the section "B.1.2."
seemed that it went through,then the version become Product version.
I just read the ug-pac-security-n3000.pdf,it says "This operation is permanent and irreversible."on page 21.Does that mean root entry hash bitstream is programmed,I even don't know any keys(root key/csks),then the card is dead for me? could you help me please.
- JonWay_altera
Hi @fzhan51 If you did not create + program any root hash into the device, then it should be fine. You can still program unsigned images.
- fzhan51
would you help to login our n3000 server to check what's going wrong? much appreciated if there is your email to send teamviewer id /psw. i just send it to [email protected] i don't know whether you can received it or not.
i Update the Intel XL710 Firmware,and after rsu bmcimg <FPGA PCIe B:D.F> the server hang.attached is the sreenshot
- JonWay_altera
Hi @fzhan51 I see you have created another thread https://forums.intel.com/s/question/0D50P00004dmzbn/pac-n3000-8x10g-xl710-update-failed?language=en_US&t=1586513388811 on the same issue.
But i probably continue to help from here, and close the duplicated.
Could you run lspci -s BDF_OfTheEthernetCtrller -x
Expected to see something like:
00: 86 80 f8 0c xx xx xx
I see that your version is up-to-date, and if the lspci command as above is ok...then probably you can try to move on
- fzhan51
so glade to get your answer.
[root@localhost Factory_Image]# lspci -s 07:00.0 -x
07:00.0 Processing accelerators: Intel Corporation Device 0b30
00: 86 80 30 0b 46 05 10 00 00 00 00 12 08 00 00 00
10: 0c 00 f0 ff 3f 02 00 00 0c 00 e0 ff 3f 02 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 00 00
30: 00 00 00 00 68 00 00 00 00 00 00 00 0a 01 00 00
- JonWay_altera
Hi @fzhan51 I noticed your log. The bitstream id, is
[fpga@localhost ~]$ sudo fpgainfo fme >> /home/fpga/fpgaxx.tx
Board Management Controller, MAX10 NIOS FW version D.2.0.19
Board Management Controller, MAX10 Build version D.2.0.6
//****** FME ******//
Object Id : 0xF400000
PCIe s:b:d.f : 0000:07:00.0
Device Id : 0x0b30
Numa Node : 0
Ports Num : 01
Bitstream Id : 0x21064001020134
Bitstream Version : 0.2.1
Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846
Boot Page : user
You should be getting the bistream id as below. It shows that something did not install correctly.
You mentioned that you followed the Beta (by mistake)...can you still run the instrucction on upgrading from Alpha?
- fzhan51
Bitstream Id differs when fpgasupdate with unsigned.bin of different version,
the Bitstream Id of pac_n3000_rtl_1.3.15.tar.gz unpacked from n3000_ias_1_1_pv_patch01.tar.gz
is 0x21064001020134 while which form pac_n3000_rtl_1.3.6 is 0x23000010010309(in this case,the same result).
run the instrucction on upgrading from Alpha now failed,I don't know how to do it again.
here is the cmd goes:
[root@localhost 10G]# super-rsu super-rsu.json --with-rsu
[2020-04-05 15:09:32,028] [WARNING ] [MainThread ] - Update starting. Please do not interrupt.
[2020-04-05 15:09:32,332] [WARNING ] [07:00.0 ] - fpgaflash bmc_img max10_system_revd_dual_v111.2.13_temporary_default_fpga_die_cfm0_auto.rpd 0000:07:00.0 exited with code: 1
[2020-04-05 15:09:33,031] [ERROR ] [MainThread ] - not all boards updated, failing now
[2020-04-05 15:09:33,032] [INFO ] [MainThread ] - super_rsu.pyc update completed in: 0:00:01.003259
[2020-04-05 15:09:33,032] [INFO ] [MainThread ] - super-rsu exiting with code '70'
- JonWay_altera
Hi @fzhan51 I just checked your log, you should be running "lspci -s 06:00.0 -x"
That should point to the XL710, and if the ID shows 0CF8, then thats should be fine.
- fzhan51
Dear JwChin,
[fpga@localhost-localdomain modelsim_install]$ lspci -s 06:00.0 -x
06:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 Intel(R) FPGA Programmable Acceleration Card N3000 for Networking (rev 02)
00: 86 80 f8 0c 46 05 10 00 02 00 00 02 08 00 80 00
10: 0c 00 80 93 00 00 00 00 00 00 00 00 0c 80 01 94
30: 00 00 f8 ff 40 00 00 00 00 00 00 00 07 01 00 00
- JonWay_altera
Hi @fzhan51
Could you run this:
fpgaflash bmc_img max10_system_revd_dual_v111.2.13_temporary_default_fpga_die_cfm0_auto.rpd 0000:07:00.0 --log-level=state
- fzhan51
fpga@localhost-localdomain 10G]$ sudo fpgaflash bmc_img max10_system_revd_dual_v111.2.13_temporary_default_fpga_die_cfm0_auto.rpd 0000:07:00.0 --log-level=state
usage: fpgaflash [-h] [-r] [-n] [-y]
{user,factory,factory_only,rsu,eeprom,phy_eeprom,bmc_bl,bmc_app,bmc_fw,bmc_img,bmc_factory,dtb}
file [bdf]
fpgaflash: error: unrecognized arguments: --log-level=state
- JonWay_altera
Hi @fzhan51
Could you run just this line: fpgaflash bmc_img max10_system_revd_dual_v111.2.13_temporary_default_fpga_die_cfm0_auto.rpd 0000:07:00.0
I wonder if it will complain your intelhex is not installed.
If yes, install install hex again and run this line again.
