fzhan51
6 years agohow to test FPGA PAC N3000 network port
FPGA PAC N3000, configed in 8x10G mode, attached to the Xeron serverA with pcie x16 。we got 40GbE servrB/ 10GbE serverC , QSFP+40G SR-L optical module and 12core mo3 fiber。test case:1) serverA-->one ...
JonWay_altera
6 years agoHi @fzhan51 If you did not create + program any root hash into the device, then it should be fine. You can still program unsigned images.
- fzhan516 years ago
would you help to login our n3000 server to check what's going wrong? much appreciated if there is your email to send teamviewer id /psw. i just send it to [email protected] i don't know whether you can received it or not.
i Update the Intel XL710 Firmware,and after rsu bmcimg <FPGA PCIe B:D.F> the server hang.attached is the sreenshot
