XG_Kang's avatar
XG_Kang
6 years ago
How to assign LVDS in 1.8V bank in Cyclone VE
How to assign A LVDS clock to CLKn pins in 1.8V IO Bank in 5CEA9 device。If the LVDS clock signal name is clk1_p/clk1_n,it can be assigned to GCLK pins , but how to assign the IO Standard? All other signals in the same IO Bank is 1.8V, if LVDS IO standard is assigned to clk1_p/clk1_n, they are confilted to IO standard of other signals in the same IO bank.
  • SreekumarR_G_Intel's avatar
    SreekumarR_G_Intel
    In cyclone V, 1.8V IO bank is not support the LVDS IO standard.Can you refer the datasheet (below link) table 20. for the VCCIO requirement for the LVDS.
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_51002.pdf.
    In general assign the LVDS std to the clk pins in few ways
    i) Use the pin planner setting in the quartus -> Assignments->Pin planner -> dropdown menu to assign the IO standrads,
    ii) using Tcl assignment in qsf file, for example
    set_instance_assignment -name IO_STANDARD "LVDS" -to "net_name_to assign(p)"
    set_instance_assignment -name IO_STANDARD "LVDS" -to "net_name_to_assign(n)"
    Thanks ,
    Sree
